We’ve Added New Components to our eCatalog! – April 2021
We’ve added 69 new components to our eCatalog! Check out the latest additions from Autonox Robotics, Fanuc, IAI, Igus, KUKA, OnRobot and Visual Components!
One of the biggest benefits of buying Visual Components is the vast library of pre-defined components to which you’ll have immediate access. With 1,500+ robots from more than 50 of the largest brands in industrial automation, Visual Components offers its users one of the most substantial libraries of pre-defined components in the industry, at no extra cost! Check out the Visual Components web eCatalog and see for yourself!
We regularly add new components and layouts to our component library, and our engineers have just completed a new batch of components, which are now available in the eCatalog. We’ve added 69 new components.
Autonox Robotics
- articc6-1199-3kg
- articc6-1557-3kg
- articc6-1959-60kg
- articc6-2118-45kg
- articc6-2257-30kg
- HD RL4-1000-6kg
- HD RL4-1100-1kg
- HD_RVS3-T1-400-12kg
- RL4-1200-6kg
- RL4-400-0.5kg
- RL4-T1-1600-20kg
- RL4-TS1-ATS-1300-6kg
- RL5-1250-6kg
- RLE4-1200-6kg
- RLZ4-1200-3kg
- RV2-900-40kg
- RVS2-T1-600-6kg
Fanuc
- M-410iC/185 Compact Base
- R-2000iB/150U
IAI
- IXA-4NNN1805-5L-T2
- IXA-4NNN3015-5L-T2
- IXA-4NNN4518-5L-T2
- IXA-4NNN4533-5L-T2
- IXA-4NNN6018-5L-T2
- IXA-4NNN6033-5L-T2
- IXA-4NSN3015-5L-T2
- IXA-4NSN4518-5L-T2
- IXA-4NSN4533-5L-T2
- IXA-4NSN6018-5L-T2
- IXA-4NSN6033-5L-T2
- IXA-4NSW3015-5L-T2
- IXA-4NSW4518-5L-T2
- IXA-4NSW4533-5L-T2
- IXA-4NSW6018-5L-T2
- IXA-4NSW6033-5L-T2
Igus
- Drylin Servo Axis
- Drylin E Flat Linear Robot – Working Space 300×300 mm
- Drylin E Line Robot – Working Space 500×100 mm
- Drylin E Line Robot – Working Space 800×500 mm
- Drylin E Room Linear Robot – Working Space 400x400x150 mm
- Drylin E Room Linear Robot – Working Space 500x500x100 mm
- Drylin E Room Linear Robot – Working Space 800x800x500 mm
- Robolink 4 – 510 – Integrated Controller
- Robolink 4 – 510
- Robolink 4 – 620
- Robolink 5 – 680 – Integrated Controller
- Robolink 5 – 680
- Robolink 5 – 790
- Robolink DP4
- Robolink DP5
KUKA
- KR 140-2
- KR 4 R600
- KR6_R500_Z200
- KR6_R700_Z200
OnRobot
- MG 10 Gripper
- VGP 20 Gripper
Visual Components
- Milling Machine, Shuttle Automatic Pallet Changer
- Signal Relay
- Automatic Shrink Wrap Machine
- BoxLabel
- Case Labeling Machine
- L-Sealer Shrink Wrap Machine
- Shrink Tunnel
- Sleeve Shrink Tunnel
- Sleeving Machine
- Stretch Wrapper
- Tamp Labeling Machine
- Wrapping
- Sleeved Bottle
We’ve Added New Components to our eCatalog! – December 2022
One of the biggest benefits of Visual Components is the eCatalog's vast library of pre-defined components. With 2,700+ components from more than 60 of the largest brands in industrial automation,...
We’ve Added New Components to our eCatalog! – August 2022
One of the biggest benefits of buying Visual Components is the eCatalog's vast library of pre-defined components which you’ll have immediate access to. With 2,700+ robots from more than 50...
We’ve Added New Components to our eCatalog! – September 2021
We’ve added 60 new components to our eCatalog. Check out the latest additions from ABB, ABI, Cobot Lift, Comau, DF Automation and Robotics, EasyRobotics, Fanuc, Haas, KUKA, Nachi, OnRobot, Panasonic,...
